Dyno Report 9.8:1 vs. 8.7:1 Whipple Tune
#22
90? hmmmm, i could join you guys in the 500 club if that's the case.
i've actually been thinking of creating my own tune, or going back to my guru
for another dyno tune, this time based on 12psi and the stock cams. at
10psi with the hot rods, i was at 467rwhp.
i'll watch for your thread, maybe it's up now...
Not sure of the timing, but i'm installing an aeroforce in a roush vent pod
this week and then i'll be able to tell you.
#27
yeah i saw the thread......it sure is shiny and i like the logo
on top. the fact that frpp says tune required, seems promising.
i may or may not make it....i think i'm drawing the line in the
sand at 12psi. i just don't see any need to go above that at
this time.
i have a feeling explicit is going to surprise us all, with some
hefty numbers.
this time.
hefty numbers.
#28
I'm not sure exactly what the FRPP throttle body is, but usually when you step up to a really large TB, mine is 130mm, you will gain 20+ rwhp and extra pound of boost. Combine that with a few degrees of timing, cleaning up the AF through out the RPM range and you your car will turn into a monster.
When dyno tuning on Saturday, this particular program had peak HP and TQ and averages for both. My peak TQ was like 510 or so, average was 400+, by cleaning up the AF in the middle and maybe adjusting the cam timing, it went up like 60-70 rwtq, but the peak number stayed the same. A good tuner will make a pull, look at the graph, write down notes, tweak the AF and maybe the timing, make another pull and do it again.
This where, "Power under the curve" comes into play.
#29
this time.
hefty numbers.
this time.
hefty numbers.
#30
So I'm in a dilema, I need 4.10 gears, but I need some better cooling for IAT's to make the 4.10s worth it. So I will be shopping around for a larger HE, ice box of some type and another IC pump if needed.
