Uh, help?
Last week i pulled all 8 plugs, cleaned them, and gave the engine the Seafoam treatment. Now she has an inconsistent miss and will sometimes stumble at WOT between 1500-3000. Did i make a boo boo or could it be something simple?
When SF is added to the fuel and left in there for a certain period would it have a negative effect on the fuel? I'm not prepared nor willing to shell out $90 on new plugs. |
its most likely plugs man, make sure they are put back in correctly.
Originally Posted by howarmat
(Post 6976973)
The 2 piece crap plugs from the factory are quite fragile. A lot of times, the torque to remove them will screw them up inside and cause just such a miss. You might be looking at a new set of plugs after all. Were they hard to get out?
Originally Posted by Goldenpony
(Post 6977106)
Originally Posted by Swervin309
(Post 6977109)
Yeah, i had to put a little @$$ behind em. I started playing around and i determined that it was the #2. I unhooked the injector harness on each one until i got a consistent miss. Is it safe to swap just one plug or is it better go ahead and do em all?
Originally Posted by 07 GT E UPP
(Post 6978737)
At this point, If I was you.... I would replace them all, and with proper gap..!!
(Post 6980982)
Runs like a dream.
glad to hear it all worked out |
(Post 6980982)
Yeah, i did. I was sure to put anti-seize compound on them. Runs like a dream. Unfortunately, the gap on the plugs in non-adjustable.
Originally Posted by Simon1
(Post 6990618)
Where did you hear that? I adjust mine down to .034.
