Axle Question...
Old 05-22-2010, 04:34 PM
ProCrsh
ProCrsh's Avatar
Default Axle Question...
ok so , since i smacked a curb almost a year ago i've had a squeak coming from the rear on the drivers side. i finally got around to trying to figure out the problem and i thought it was a warped rotor, then i realized i have a high point because it rubs. im pretty sure i have a tweaked axle and i wanna get a second opinion from you guys before i got buy one. also kinda wanna pick your brains about which way to go with a replacement.
Vinny
ProCrsh is offline
Old 05-22-2010, 05:48 PM
socalwrench
socalwrench's Avatar
You really need a needle gauge to measure the runout of the axle. It's true, you could bend the axle and/or the flange. As far as replacement goes, I would look into a used Ford one from a yard, dismantler or private seller.
socalwrench is offline
Old 05-23-2010, 08:13 PM
ProCrsh
ProCrsh's Avatar
any other ideas?? i did speak to a guy today, he was also saying it could be teh flange... either way i need a needle guage
ProCrsh is offline
Old 05-25-2010, 04:51 PM
sailing220
sailing220's Avatar
This happened to me, same exact noise, but on mine the caliper bracket started eating into the rotor. New Moser axles fixed it right up.
Don't buy Superior Axle.
sailing220 is offline
KingRando
10-02-2015 08:06 AM
marc954
09-29-2015 11:18 AM
lincolnshibuya
09-24-2015 10:46 PM
09-24-2015 09:18 PM
09-10-2015 08:39 PM
Quick Reply: Axle Question...
