UPR catted X-pipe?
Old 06-01-2010, 10:27 PM
cidsamuth
cidsamuth's Avatar
Default UPR catted X-pipe?
Okay, I understand the different between the X and H pipe sounds. However, since I already have an O/R Roush exhaust, I'm really concerned about going with an O/R X-pipe because of noise level.
I'm pretty sure that eliminating the cats would have gotten me 10 - 15 HP. Well, what about with aftermarket cats, like the UPR catted X-pipe? Any HP to be gained, or would I be installing it only for the difference in sound between my stock H pipe and the UPR X?
While UPR says it gets "up to" 20 HP out of its catted X-pipe, I really doubt it.
cidsamuth is offline
Old 06-02-2010, 10:21 AM
gman73
gman73's Avatar
I have no experience with UPR products but I have heard that they are low quality. A friend of mine who is a co-owenr of a mustang shop says he will not order UPR because of the quality. As far as hp gains, in my experience compared to the stock catted H, O/R midpipes gain hp but lose tq and hi-flow cats gain both hp and tq.
gman73 is offline
Old 06-02-2010, 12:45 PM
cidsamuth
cidsamuth's Avatar
Thanks, gman. I guess if I want hp gains without the excessive noise, the key will be finding good "high flow" cats.
Do you have a recommendation? I read elsewhere that all the major brands (Kooks, BBK, JBA, etc) use the same cat manufacturer, but don't know if that's true.
Old 06-02-2010, 12:59 PM
UPRDanielle
UPRDanielle's Avatar
You will definitely see a power gain from replacing your factory mid pipe with an aftermarket mid pipe. I wouldn't question the quality of UPR's x-pipe's, tho. I had one on my old GT and it sounded great, worked perfect and I had no problems with exhaust leaks. Honestly, I have a Bassani x-pipe in my Cobra only because it's temporary (in the process of installing a turbo) and every oil change I have to adjust and tighten the slip fit pipes and clamps because I ALWAYS have leaks...even put high temp RTV where the pipes meet, and it didn't really help. lol
UPRDanielle is offline
Old 06-02-2010, 07:43 PM
gman73
gman73's Avatar
Even though I have pypes catted X, I would go with magnaflow tru-X. I got the pypes catted X off a local seller, brand new for $300, so I can't complain. The pypes is PITA to instal as you have to cut the legs to slip in the cats. I ended up taking to an exhaust shop so they could fix it and weld in the cats. Bassani also has slip on cats. I would have these welded on. Also bassani is not a true x pipe but more of a clam shell shaped. It has it's own unique sound.
gman73 is offline
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
firecoyote
09-27-2015 02:37 PM
09-24-2015 09:18 PM
UPRSharad
09-08-2015 03:46 PM
Quick Reply: UPR catted X-pipe?
