Man, I think I wiped out my tune.
I didn't see any answers here:
https://mustangforums.com/forum/4-6l...-now-what.html
Guys I disconnected my battery because I planned on wiring up some gauges. I think I wiped out my custom tune. I thought a tune would be "saved" and not have to worry about it resetting. Dumb move on my part.
The shift points became smoother. There is no kick when she should have started boosting. My speedometer re-cal'd, and is now off (I have shorter tires, so I had to cal my speedo). Plus, I have my Trinity up for monitoring, and now my FRP is fluctuating between 35-60, instead of sitting tight at 44-45.
It was custom-tuned with an SCT, which I have on-hand. Can I plug that up to see if that tune is still saved on the device? Or would that do more damage than good?
Thanks in advance!
Thanks in advance!
Disconnecting the battery should not wipe out your tune, but if you have the SCT with the tune on it you can definitely just reload it. I do that about every other month or so anyway when it feels like the adaptive learning has softened it up some.
Yep...re-applied the tune.
I can't say that I am completely buying into the re-tune to get back my 491/420, though. I need to get it back to my shop to have them take a look. There are still inconsistencies between what I re-applied and what I lost. For instance, when I started it up cold before I ****ed with my battery, it idled high (2k) for about 8 seconds, and then dropped off. I cranked it a little while ago (after it sat for a couple hours), and it idled right around 900rpm. Granted, it's a hot day here in the DC area, but still.
Maybe I'm nuking it, but even though I felt the "boost kick", it didn't feel like it should have.
Anyway, thanks fella. I'm taking it to the shop this week to have them once-over it.
Also - your lack of "boost kick" could also be attributed to the heat wave we're seeing right now. Depending on how aggressive your tune is, it's even possible your knock sensors are pulling timing when you get into boost compared to when the weather was a bit chillier. This will result in (potentially) a lot less power.
mungodrums
09-29-2015 09:18 PM
