new gears which bearing kit?
hey guys just got new gears and was wondering what kit is best to go with for 4.10's (ford racing). I was looking at this and was wondering if i should go with that. American muscle has the motive kit but will that work?
thanks guys
http://www.buyfordracing.com/shop/pr...=692cPath=3_37
thanks guys
I don't know if the B1 will fit being it's for 07+ GT-500's and Bullitt's I never bothered to ask FRPP if it would. Here is the listing I use. I know for a fact the "C" will NOT fit due to different axle bearings on 05+
M-4210-A
* Kit includes: pinion and carrier shims, crush sleeve, pinion seal, pinion nut, ring gear bolts and cover gasket
* Use for changing ring and pinion gear or differential
* Fits IRS
M-4210-B
* Includes everything that M-4210-A has and pinion gear and carrier bearings
* Fits IRS
M-4210-B1 For 2007 & Up Mustang SVT
• Fits 2007 - 2009 SVT Mustang and the 2008 Special Edition Bullitt
• Includes everything that M-4210-A has and high torque pinion bearing and carrier bearings
• High torque pinion bearing used in 2007 - 2009 Mustang SVT and Special Edition
• Use for changing ring and pinion gear or differential
M-4210-C
• Includes everything that M-4210-B has and axle shaft bearings and axle shaft seals
• Fits 1986 - 2004 Mustang for NON-IRS axles
M-4210-A
* Fits IRS
M-4210-B
* Fits IRS
M-4210-C
Golfsito
10-06-2015 11:02 AM
musnicki
09-23-2015 07:11 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
