My advice for those getting P0133/0153 codes from LT headers
...give your car at least 5 minutes to warm up at cold start. I was getting these codes in my car every 2 - 3 days, even after checking the O² sensors, and revising the tune files. They were fine.
I noticed I was getting these codes the mornings when the alarm clock didn't wake me up on time, and I just got on the car and left hastily. I started letting the car warm up 3 - 5 minutes each morning and those trouble codes haven't returned in a month of (daily) driving. Same tuning.
Just a heads up.
Just a heads up.
found a fix for the problem on another forum. it has to do with the self-test timer for the PCM and O2 sensors. the fix seems to be retarding the test timing a tiny bit. this gives the O2 more time to warm up prior to be tested.
the theory is that moving the front O2's from their OEM location to about 1.5 feet farther downstream causes the O2 to heat up later...but the PCM is still looking for the self-test at the same time. So the O2 "fails" and the PCM never goes closed loop. Makes the car A/F go pig rich and then CEL's and poor driveability.
BTW... also...
EVERY long tube job on these cars should come with a tune that turns off the rear 02 sensors. PERIOD.
If not you will eventually get cat inefficiency codes thrown at you.
Luke9222
10-22-2015 11:55 PM
trashxtrash
09-20-2015 10:49 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
