K&N Problem
Old 09-11-2010, 09:03 PM
Red Wunz
Red Wunz's Avatar
Default K&N Problem
I replaced my Spectre CAI with the K&N FIPK setup and now my vehicle won't start. I get one rev on startup and the engine dies right away with no response from the accelerator. Near as I can tell I put everything together correctly, so what could be causing this?
Red Wunz is offline
Old 09-12-2010, 09:52 AM
Casey4s
Casey4s's Avatar
Check your MAF sensor. Their customer service is steller, if you can't figure it out contact James at K&N customer service.
Casey4s is offline
Old 09-12-2010, 02:26 PM
Nuke
Nuke's Avatar
+1 on the MAF. Unplug and clean the connectors.
Are you tuned for a CAI? If not, then why are you wasting your time with no-performance-to-speak-of CAI's? Get the real deal from AM or Brenspeed; CAI and custom tunes.
Nuke is offline
Old 09-14-2010, 12:16 PM
mapitts
mapitts's Avatar
Also make sure the MAF is pointed the right way. I do not think you can get it in backwards, but make sure. You may also want to make sure that the boot that goes around the throttle body is on the throttle body all the way around.
mapitts is offline
Old 09-18-2010, 12:14 AM
goose5
goose5's Avatar
As stupid as this sounds is there a balled up peice of paper or packaging in the tube?
goose5 is offline
Seanam
10-04-2015 10:15 AM
mdj89
09-23-2015 08:49 AM
kachuy10
09-22-2015 01:27 PM
stangin1996gt
09-21-2015 11:01 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
Quick Reply: K&N Problem
