FORD MOTORSPORTS INTAKE
i just installed a ford motorsports intake on a 2007 gt
it lost gobs of low end, and does not seem better at high end.
it has comp cams with springs
bbk throttle body
k n cold air
no mufflers
under drive pulleys
american muscle programing
any help!!!
bbk throttle body
k n cold air
no mufflers
under drive pulleys
any help!!!
intake
had 3 new downloads for programer
1 for street , 1 for race and 1 for performance. tried street and performance , without much difference in drivability. reading more about the manifold it says, improved top end above red line with minimal low end loss.
i guess that means there is low end loss. i can hold to 6000 rpm, pop the clutch and it wont even break them loose. not like before. the first time i tried a launch i puched the clutch back in thinking i was launching in 3rd gear, but i was in 1st. i think i will try 4.10 gears. or put the old intake back on. i also am going to call bama tuning to see if they can help..i think its a pretty new product and may need to try a different tune?
Yes you have to read between the lines. MM&FF did an article on it 1 or 2 issues ago. The headline was 30 extra HP but if you look at the dyno numbers it lost 30 torque all the way up to 6,000rpm
Are you talking about the FRPP intake that is also used on the Bullet?
If so, you won't feel much difference between it and stock. It's got an 85mm MAF housing (bottleneck) because of that nearly 90 degree angle the intake makes just out of the air cleaner housing. You should get a C&L with a more straight shot and larger diameter MAF housing.
