best gears for a roots style sc and a auto
I went from 3.31s to 3.73s in my 09 with the Vortech on it, and was disappointed. I wouldn't have done that swap again in retrospect, there was just very little difference. I noticed much more positive results from the aluminum driveshaft. I would say if you must do gears, go all the way to 4.10s or don't bother. ymmv...
i have 3.73s in my magnacharger mustang! they are perfect!! trust me, 3.73s are what you need, now if youre going strictly race and have the right tires, then id suggest 4.10s but only if youre running slicks
As you can see you will get cheer leading from both sides. As mentioned if your going to the track quit often go with the 4.10's and if not go 3.73's. I went with the 3.73's, happy with my decision and noticed a nice difference from the stock 3.31's. I have a Whipple, a PH Drive shaft and my suspension is setup. Gonna get some track time this season everything closed for the winter.
what are the sizes on those rims?? that looks awesome
My car came with 3.55 gears stock. I've kept them, as the power + my street tires makes anything steeper mostly unusable on the lower end.
I think the right answer will really depend on what you plan to do most often with the car. For me, 3.55 + blower is plenty for me. Now, if I was drag racing the car often, and had the tires to support it, 4.10's would probably be a lot of fun as well.
thanks for all the replies.. If I play it will defintely be on ET Streets... Nem I love the way that car sits... Vettehunter I was thinking about some cams mabye Detroit Rockers or Brenspeed has a grind for a Twin Screw , but I am a roots would it be that different; such as overlap and valve timing? What does anybdoy think about Pypes LT's... Again Thanks... Joe
