Exhaust Install with Jack Stands
Solid 10x10x10 blocks is a whole lot different than typical cinder blocks. I suppose I'd be ok with that. Except now I think you should have kept going higher so you could work underneath while standing up. Now THAT I'd like to see. Of course, I'm not sure where you'd put the bracing to keep it from swaying... LOL!
I ended up buying some good sturdy 6 ton jack stands. The advantages of getting 6 ton over 3 and 2 ton is that you can get a lot more height and they definitely are a lot more sturdy.
Just make sure you get a good quality jack that will go up high enough so you can take advantage of the height the 6 ton stands can provide. I think my 6 ton stands can go as high as 24 inches.....though you probably only need to go about 20 inches on just two stands and you should be able to get under the car and go back as far as the H pipe and change out your exhaust.
I would recommend a 3 or 3.5 ton jack....a heavy duty one.
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
