2007 oil pressure and water temp gauge install questions
I have searched and searched and while I'm sure that using the Brass T to hook up the oil sensor isn't the wrong way.... I wanted to know if anyone has Taped into the motor some other way to get the pressure sensor working. Any help on where you taped in let me know please.
Also still doing research on where to tap for water temp. any help would be appreciated.
I read this in the "how to forum". It should help.
https://mustangforums.com/m_4554210/mpage_1/key_/tm.htm
I'm also going to be installing an electric oil pressure gauge so I had some interest in this. I found this on another forum.....it appears you have to create your own T fitting. I attached the link.
http://www.stangnet.com/mustang-foru...ure-gauge.html
