Please look at the age of a thread before replying. Also, everyone knows E85 doesn't help MPGs and is worth running if you want those power gains especially with FIs.
What are you, the Law? I know the age of the thread...thanks. Was doing a search to see what other's MPG's are compared to mine.
My 2010 won't run E85 and I try not to run any ethanol at all since it's just a water introducing source to your metal internals.
For a daily driver/naturally aspirated, yeah, you're better off without any ethanol. For boosted applications & high compression engines, there is something to be said for ethanol content. It's a less dense fuel so it takes more volume t create the same energy, which means it has a greater cooling effect on the charge air, reducing chances of detonation or pre-ignition, allowing higher fueling rates, more timing, and more boost... which equals more horsepower.
Last I checked I was getting 13 smiles/gallon average @16 PSI & 750 RWHP with 91 octane (with up to 10% ethanol).
Your 2010 could run E85, all you would need to do would be to upgrade the injectors to a higher flow rate, replace the fuel lines, get an E85 tune and add a boost-a-pump. You would of course lose about 25%-30% of your MPG.
talldude, NUKE is right on the money. But, NUKE left out one valuable piece of information. Good gas mileage begins with proper control of a heave right foot. Believe me, I'm pushing 450 RWHP out of my 2014 GT and I watch the fuel gage drop like a rock every time I even think of destroying a "rice burner." My GT has never seen anything but E-free 93, and I knew this going into cloud 9 when I bought the vehicle. This is not the vehicle to be looking for great gas mileage with. Other than that, install a set of 2.87 rear gears and never look back.
