Kenne Bell 2.6 Stage II install and POS plugs
My builders at KY Speed just finished up the install of a Kenne Bell 2.6 Stage II supercharger on my Son's 2005 GT. Everything went great on the supercharger install. I took it for a tune late last week and about half way through the process we had issues with detonation above 4,000 rpms so we decided we needed new plugs with less of a gap a step colder. Started to take them out and none of them would budge, we looked on the internet and found all the stories about the broken spark plug issues on these motors so I brought the car home and soaked them for 24 hours with sea foam. Still only one plug came out normally, we soaked them with carb cleaner for another day and still the rest had issues. I ended up having to break them, tap them and extract them with a special puller tool. Once I understood what I needed to do I got them out without any issues or fears of stuff getting in the cylinder’s at all. Just lost a lot of hours on my life doing this, but now I see it as no big deal, just got to take the time and do it right. I am now known as the Spark Plug Kking around here LOL. Got a new set of Brisk plugs installed in the car which are one step colder and it run great, so the tune is already very close. We are going back to the tuner on Monday to finish up the tune and see what this puppy will put down on the dyno to the wheels. With headers we are looking for about 9 lbs. of boost. We have done tons of Chevys but not many Fords so do you experienced guys have any guess on the HP and torque we should see? The car has headers, Corsa exhaust and an X-pipe, the Kenne Bell boost-a-pump and the Stage II SC with 410 gears. Do you have any words of caution or other things we should look out for? Any good feedback would be helpful.
Below are some of the build pictures.
The factory KB tune was detonating above 4000rpm? Wonder what KB would say about that since they consider their tunes to be pretty much perfect.
Also running brisks with my stage 1 setup. I'll be curious to see what type of whp numbers you get on the dyno with yours.
What other mods do you have and what kind of numbers are you doing with your car?
Here is a cold start up video of my Son's car before we got the plugs changed.
Sorry to hear about the plugs being such a pain. The brisks are a one piece so they shouldn't be a problem if they are even in there long enough to start getting stuck which I doubt.
Doesn't surprise me KB wasn't real thrilled about tuning remotely for those headers. They usually tell you a custom tune is required for that which is going to happen in this case anyway.
Wish I had numbers to give you. Haven't had it on the dyno yet and there is only one of those in town here that I know of. Maybe this summer. The guy who had this kit before me (stage 1) hit 440whp peak on a mobile dyno with the KB tune on a hot summer day. Had 20" wheels on the car and 3.73 gears.
What other mods does yoiur friend have?
The brisk plugs that are in there right now have around 2000 miles on them. I'm not really sure why but for whatever reason it seems like people are changing plugs a lot on these mustangs when they are supercharged. I think it's Simon on here who has a KB kit and claims he has to change his literally every 3000 miles or so. I can't speak to that because I haven't had mine long enough yet to know whether my car will go through plugs that often. I am hoping not especially since the compressor might have to come off to get the plug that is at the rear passenger side. We'll see though, should have about 3000 or more on there by the end of this summer.
Regarding the mods that were on the car that hit 440whp with this kit it was stock engine 100% (cams, intake, exhaust) and had just the aftermarket 3.73 gears. That was it. Stock KB stage 1 tune.
FWIW on my Son's car all you have to do is remove the throttle body and you can get to all the plugs fine.
Thanks again for the info, I pinged Simon1 on this as well
Thanks for the tip. I'll try to remember and let you know what happens with my plugs. I was also not exactly thrilled to hear about that issue. At a whole new set every 3000 miles it's gonna get spendy. Pay to play I guess. Better than a blown engine lol
Thanks
