Novi 2200 39lb with BAP WONT START - MustangForums.com
Old 03-12-2011, 10:02 AM
05REDROUSH
Default Novi 2200 39lb with BAP WONT START
I just put in a new NOVI 2200 in my 05 ROUSH. I have 39lb injectors with a BAP (always on). Started it yesterday and it ran fine. Today however it wont start. Sounds like its out of gas (but its not). I have a dyno tune appt this week and just need to drive it there. Any thoughts. Thanks for the help. Oh, I have an SCT programmer, but cant do anything with it because BAMA doesn't make files for a Paxton SC.
05REDROUSH is offline
Old 03-12-2011, 10:18 AM
RedFire281
Did you twist tie the connections on the BAP or solder them. If they're just twisted then check the connections to insure none of them vibrated loose. Check any ground connections, too. Also, did you press the fuel pump inertia button on the drivers side kick panel?
RedFire281 is offline
Old 03-12-2011, 11:19 AM
red96v6
red96v6's Avatar
Maybe check the fuses too. Can you gear the fuel pump turning on?
red96v6 is offline
red96v6
red96v6's Avatar
Wait, you don't have a tune for the supercharger?
red96v6 is offline
Old 03-12-2011, 11:48 AM
05REDROUSH
Thanks for the help. Just double checked the BAP and Pushed the reset button. Still nothing. It seems like its almost there and wants to turn over put then it dies out. Any other thoughts?
Old 03-12-2011, 11:50 AM
05REDROUSH
I hear the FP running. No I don't have a custom tune on the car yet, but it should still turnover. I reset the OBDII with my SCT to see if that would work, but nothing.
Old 03-12-2011, 02:44 PM
nitrobob
Turn the BAP all the way up. Probably still wont start without a tune. What tune did you have the first time you heard it run. Pull the battery cable for a few minutes then reconnect and see if it starts. Other than that ???? Is it intercooled???
nitrobob is offline
Old 03-12-2011, 02:46 PM
05REDROUSH
So after all your inputs and some trouble shooting on my own I have fixed the problem. Took the coils out and cleaned them, looks like some fuel from the rail got into one of the coils, not alot but I guess enough to cause me a headache. So now I can take it to have it dyno and tuned. Wish me luck! Thanks again for all the inputs.
Old 03-12-2011, 03:29 PM
nitrobob
Cool...Glad you got it figured out..The paxton set-up is a beast. I really like mine.
nitrobob is offline
Old 03-12-2011, 07:18 PM
red96v6
red96v6's Avatar
Good luck, let us know what it puts down!
red96v6 is offline
zsmart
Convertible Tech
02-29-2016 08:33 AM
1TUFF302
11-05-2015 04:02 PM
StalkerGT
09-25-2015 02:41 PM
dalefrancis88
09-11-2015 07:15 AM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: Novi 2200 39lb with BAP WONT START
Featured Sponsors
