Are the best cats for Supercharged/Long Tubes the Pypes Metallics?
Did you put the cats in just for the physical inspection?
I turned off the rear O2 Sensors and I am not throwing a code otherwise. If I get past the issue of the physical inspection, do you think there would be an issue? The inspections here just read through the ODBII port, so I am guessing they are looking for problem codes...
The aftermarket cats or the "hi flow" cats are the type I always see have problems with not passing emissions, melting or clogging. I have seen it in the OEM cats also, but rarely.
ZI have ran 550 rwhp for 3-4 years, most of it with cats (OEM) and have never had a problem. I actually prefer the cats to be in the car because it is much quieter and it doesn't stink. But since I race and use a two step at the line, I need to be catless so I don't foul up my cats. Unless I found some used cats or a new take off H pipe, I would have to spend around $550 to get them replaced. Its cheaper and easier for me to spend $200 on an off road pipe and put it in for inspection and take it out when race season begins.
Ney York reads to ensure the O2's are ready. If you have them off you will fail inspection
daltron
04-28-2016 08:10 PM
KingRando
10-02-2015 08:06 AM
09-24-2015 09:18 PM
