Driveshaft upgrade ?
When i get my GT i want to put a single piece DS in
Ive seen one on americanmuscle but i have also heard good things about "Shaftmasters"
they are also cheaper.
What are you running and how do you like it?
Thanks again
Thanks again
I have a 1 piece DS, can't remember the brand. It I like it.
Car feels snappier, smoother shifts and I get better fuel economy.
The down side is that it is noisier than OEM. I was told that it would be noisier because I was lowered. On smooth roads it's perfect but on bumpier roads there is some squeeking.
I have Shaftmaster and fully recommend them. Sometimes you have to be suspicious about quality when buying cheaper parts, but not the case with them. Good product, excellent customer service. Stock DS was 38.8 vs 18.5 aftermarket.
Car felt a little zippier, and removed the "thunk" when shifting from drivetrain slop. Also made everything feel tighter, kinda hard to explain.
I am running a Dynotech on both my GT & Snake...bolt on and no problems...
In my experience, you might get more vibration the lower your car is. I've got a 1"/1.25" front/rear, and the only vibration I get is a little bit at startup. Someone mentioned it above, but the car definitely feels "snappier"...but I'll also say "more put together". Mine is Shaftmasters, by the way. There was a period, recently, where they were out of stock though.
Matt's 95 Stang
10-05-2015 07:16 AM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
