My Stang is eating spark plugs!
#22
Why not???? Unless I don't remember, it's been a few years, but I do seem to remember that the Red Loctite is the stronger one. Anyway, I did use the stronger one. the Loctite is holding the Helicoil in, not the sparkplug, genius. It sounds like you don't even understand basic cylinder repair. How the hell else are you supposed to secure the Helicoil? With Elmers Glue?? I have one of the most modified Mustangs in here; it will run 10's on a good tire. Who's the bright one now, dummy? Oh, that'll be you. Edit your post before you really start to sound like as assh*le.
#23
Once again.... the loctite is holding in the HELICOIL; not the sparkplugs, ya' dummies. Do you guys even know what a helicoil is? Some people are so stupid.... I have had the plugs out at least 4 times since I USED LOCTITE to secure the HELICOILS in. That is per the instructions, but one has to know how to read to understand instructions. I am running over 15 psi, and have not had a PLUG BLOWOUT since LOCTITING IN THE HELICOILS. And I torque the plugs as per specs. Talk to me when you become more knowledgeable.
#24
Also, "one of the most modified mustangs"? Really? and 10's with a good tire is "one of the most modified" mustangs?
Dude, its great you can run 10's, but you are nowhere near the top man.
breaking
10-02-2015 01:27 PM
