I want something I can adjust the pressure with, I don't know if it is worth upgrading the injectors but If I change the pressure the engine will make better use of the fuel than stock
The S197 has a returnless fuel system that is operated by a pump and boost-a-pumps. Fuel pressure is controled by a cobination of vacuum, powered supplied by the boost-apumps (BAP), fuel pumps and whatever is commanded from your tune. A mechanical fuel pressure regulator is part of our fuel system for good reason.
If you switch to a return style fuel system, then you would probably need a regulator.
ohh okay thanks a lot for your help. People keep telling me that its an important mod but I never see them for my car guess thats why
