05 GT won't start
On the clutch pedal assembly, there's a tab off to the left side that when depressed, pushes a plunger into the clutch switch which then llows the starter to engage. Problem is, that tab apparently isn't making full contact...i'm sure I could find SOME way to shim it but I think bending the tab farther back may be a little simpler/easier. Let me know what you think once you take a look at yours.
I just took a quick look and it doesn't APPEAR to be adjustable, at least while I was twisted like a pretzel trying to see. Before I'd go bending the tab on the clutch pedal shaft, I'd put a temporary shim on the tab's backside until I found out about any possible adjustments. Here's the shop manual. I'd dig into it but I have to head out.
http://iihs.net/fsm/?dir=1
