2006 Mustang Harmonic Balancer Removal
I'm having trouble stopping my engine from turning on as i try to take off the harmonic balancer. I was told you can stop it in automatics by holding the bolt on the torque converter. Does any one know where this is? Do have to jack up the car to get to it?
http://i36.photobucket.com/albums/e1...s/622ccc2f.jpg
Converter bolt, maybe. Flywheel teeth, better chance.
Take that giant rubber plug out in your picture, the flywheel should be right behind it. A large prybar jammed inbetween the teeth and the trans case will work.
FYI, the balancer bolt is a 1 time use bolt. Once you take it out, it's no good anymore.
2nd FYI, if you don't have access to air tools, you'll likely need to put a pipe over a breaker bar for some serious torque. They aren't exactly loose.
I have the bolt off already but the engine turns while I turn the harmonic balancer with puller on it...I took this picture from another forum..I have not found this plug on my car yet..this is a pic of whats behind the plug
http://i36.photobucket.com/albums/e1...s/024eb114.jpg
