Vibrations from the rear at ~100-120mph
So I finally had the chance to take a quick pic (my car is lowered and I didn't have time to jack it up, that explains the poor quality of the pics XD) and I did a little bit of research and it seems that my Upper Arm Control is an adjustable one!
So I think that my next step is gonna be to check that pinion angle and I'll let you know what I find out. I'll keep you posted
So I think I'm gonna do like you JimC and bring my car to the shop that does all the work on my car for me. But when I talked to him yesterday, he told me to first change the rims and the tires... because the issue might come from there!
I was planning on changing anyway so that's not a big deal but do you think that it is the right approach: Changing the rims + tires and then put the car on the dyno to check where the vibration comes from?
I'd like to do a quick check on my pinion angle first, but can't find an easy way to crawl under my car with the suspension loaded...
I noticed your wheels were recently balanced? Was it a static balance or dynamic balance or road force balance?
Also, everything was ok until the rear gear install? Were the axles pulled all the way out or just pulled out enough to put the new gears in? If they were pulled all the way out, were they put back into he correct side?
I agree that is the right approach. Change them out...If the vibration is gone, then the problem is highly likely to be your rims/tires. If it's still there, then I'd focus on the pinion angle.
I think I got the standard wheel balancing.
I don't think the issue come from the gears, they have been put on by a trustworthy shop, but to answer your more detailed questions I assume they put the gears correctly...
You do have the adjustable aftermarket upper control arm. So once you verify the wheel and tire balance then get the pinion angle checked and adjusted if needed.
Do you have aftermarket wheels by the way? If so, check to see if you have the little retainer ring on one of the lugs. They are used during assembly and aren't needed afterwards. With aftermarket wheels they can cause vibration as well. I put my new drag wheels on 2 weeks ago and have vibration as soon as I got on the highway. Got back home pulled the wheels and there were the little rings, adding just enough space to cause a slight wobble.
I do have aftermarket rims but they have been on and off the car so many times (balancing, changing tires...) I doubt the little retaining ring would still be on the lug but I'll check this weekend. So to make sure I understood, this retaining ring would be between my lug and the wheel itself, correct?
You'll see the retaining ring around the stud when you pull the wheel. I know there's a picture somewhere that someone had, but almost everyone has reported vibration with those with aftermarket wheels. Worth a check. Good luck, looks like JimC has been some amazing help to you so far.
Also what torque value do you use for your lug nuts?
