So what kind of problems have you had so far?
Old 08-23-2012, 04:57 PM
  #21
pterrell
pterrell's Avatar
2006 GT with 95000. Alternator failed today and my bumper was torn off in the parking lot last week >_<
pterrell is offline
Old 08-25-2012, 08:10 AM
  #22
johngt10
johngt10's Avatar
Originally Posted by Ronny2010GT
Do you know where exactly the bad ground was? I definitely need to take a look at that. If something like this happened with me out of warranty it would probably **** me off to the point of fixing it and selling the car immediately afterwards.
Yeah its the connector on the wiring harness side. I'll try and get a pic of my old connector to show you. This connector plugs into the resistor that is in the fan shroud.
johngt10 is offline
Old 08-25-2012, 08:15 AM
  #23
johngt10
johngt10's Avatar
I want to say the ground wire was the bottom left. Either way you can see it arched pretty bad and caused the fan to no longer run.
johngt10 is offline
Old 08-25-2012, 08:40 AM
  #24
jpplaw
jpplaw's Avatar
2009 GT -stock 3.31's started whining at around 16k, tasca replaced - whined, tasca replaced-whined, tasca replaced-quiet. Strut mounts knocking @15k. Ball Joints at 25k. Hood seam and door skin bubbles at 25k.
She has 70k now.
jpplaw is offline
Old 08-25-2012, 08:48 PM
  #25
Woodys2718
Woodys2718's Avatar
2010 GT purchased new in March 2010. 15,000 miles no issues.
About the spark plugs... was Ford still using the spark plugs that could break off during removal in 2010? If so, I should get those changed.
Woodys2718 is offline
Old 08-25-2012, 09:08 PM
  #26
crankedGT/CS
crankedGT/CS's Avatar
08 gt 59k, had since new. cat converter and slave cylinder (leaking) under warranty, alternator (2 stereo amps..), replaced lca's with J&Ms when a stock bushing wore out. replaced brakes at 50k. replaced smooth driver's side idler pulley this afternoon due to whine.
crankedGT/CS is offline
Old 08-25-2012, 09:11 PM
  #27
crankedGT/CS
No. design changed early 08
Old 08-25-2012, 10:02 PM
  #28
Woodys2718
Woodys2718's Avatar
Thanks cranked.
Old 08-26-2012, 08:52 AM
  #29
Norm Peterson
Norm Peterson's Avatar
Judging by the size of the wires going to the fan, it's a pretty high-current circuit, and its connectors will tend to run a little warm anyway. Arcing could easily be a combination of vibration and heat effects.
Norm
Norm Peterson is offline
Old 08-26-2012, 09:54 AM
  #30
pterrell
pterrell's Avatar
Any tips to removing those without breaking them? I bought my 06 used so I really don't know if they were changed or not.
pterrell is offline
Quick Reply: So what kind of problems have you had so far?
