Carbureted S197?
Hey guys,
simple question. I want to know if I can replace my fuel injected plenum with a carbureted system. I've looked over the net and asked the car guys at work but no one seems to know. I've seen one guy put a 460 in his with dual holleys but I want to do it with the stock 289.
let me know if anyone know's of a part of has some ideas =)
thanks!
Mike
thanks!
Mike
I say go for it, but it's gonna cost some money. Front suspension changes (K member), motor mount adapters, and wiring harness mods - at the minimum will be required. If you want to keep your accessories, you're going to need additional brackets. There's also the question of other stuff in the car controlled by the computer (including the fuel system).
Your best bet is to try and make contact with that guy with the 460, and ask him what he had to do to make it work. You can also try contacting the various Ford/Mustang-specific car magazines to see if they have any sources for additional info. If you ask in any of the various forums, you're mostly gonna get comments along the lines of "that's stupid", or "it ain't worth it".
If you're gonna do it, I wouldn't waste my time with a "stock 289". If you're gonna be violating smog rules, you may as go as big and nasty as you can afford.
OP it could be done but it would involve lots of research and lots of $$$$. You would need to convert to a distributor setup and a stand alone ignition system like the BigStuff 3. I don't see any way you could get the stock computer to work with a carb setup.
The big question, like others have asked, is WHY? It would be a real pain and would most likely make a lot less HP then the stock system. I started racing a long time ago in the carb era and I would never willingly go back.
Earl
Earl
Earl
Earl
Hot-rodding has never been about what "makes sense", or how much it's gonna cost. It's always been about the challenge and one's own vision.
The ONLY way I see this being anything other than a pipe-dream is if you already had the chassis, engine and mounts, trans, etc and the chassis was bare of all electronics already. THAT I could see. But taking a prefectly good running car, even a V6 and dropping a carbed V8 in is MUCH more work and money than it's worth. It CAN be done, but that doesn't mean it SHOULD be done.
I remember screwing around with the Holley Double Pumpers on my Dodge 360 in my "79 truck and the 352BB in my '68 F100. They were soo much of a PITA. Every week it was something else going wrong. That and the Dodge was getting 8mpgs back then.....F100 not much better at 10mpgs.
