Paxton 2200 ,how to make it sound like a turbo?
UM put a turbo on it? common sense should of gotten a turbo in first place. idk if guys on forum will like this idea but ive seen them in the bay area alot people put these whistle in there exhaust as u accel it makes a spooling whistle kinda gay but u want turbo sound there ya go be prepared to be laughed at tho
If you want a loud bypass sound with any centrifical supercharger setup all you need to do is vent the bypass valve to atmosphere, as long as you have a blow thru mass airflow setup with won't mess with the tune or anythnig as the air is unmetered air. I run like this on my procharger. All you do is disconnect the hose that from the bypass valve to where it reconnects into the intake piping, and run a filter on the open end of the bypass valve. Obviously this wont work work with a draw thru setup, as it would be venting metered air.
Kenta08
09-02-2015 10:33 AM
