Strategy tune on SCT , help please
I got the new SCT and i managed to load the strategy tune that came with (4.6L Mustang), i couldn't find the 2 customs tunes that suppose to come with it, i found only 1 custom tunes and it killed the engine after loading it and after too many ERROR messages on the tuner + O2 codes.
So i went back to stock tune and loaded the Strategy one (also 4.6L Mustang) but it has some parameters that i didn't quite understand which one to choose.
I choose those only:
-Fuel Octane: 93
-Fuel Eco: Normal
-Fuel Injectors: Stock
-Rear O2: On
-CMCV Delete: Stock
-Air Intake: JLT CIA 100
-Traction Control: Normal
-Spark :0-2000 (0 degrees)
:2000-4000 (0 degrees)
:4000-8000 (0 degrees)
Rev limit: Drive - 6300 Rpm
Rev Limit: N - 6300 Rpm
Idle Speed: - 800 Rpm
Now what i need to know is Tire Size, i have 275/35/19 tires - what tire size shall i choose on the tuner?
I also need to raise the shift points so as to maximize the full RPM range, what to choose from those parameters below?
WOT shift 1 to 2 = 0 mph
2 to 3 = 0 mph
3 to 4 = 0 mph
4 to 5 = 0 mph
Shift Press:1 to 2 = 0
2 to 3 = 0
3 to 4 = 0
4 to 5 = 0
Any suggestions please that will improve car performance?
Thank you.
-Fuel Octane: 93
-Fuel Eco: Normal
-Rear O2: On
-CMCV Delete: Stock
2 to 3 = 0 mph
3 to 4 = 0 mph
4 to 5 = 0 mph
2 to 3 = 0
3 to 4 = 0
4 to 5 = 0
Thank you.
