I think my clutch slipped today!
I shifted into second, release the clutch and nailed the throttle. Now it's sometimes hard to tell in my car if my tires are spinning or the clutch is slipping, but I'm pretty sure I smelled clutch and the rear didn't kick sideways like it normally does and it hit 6k rpms really fast(shift light setting)
Now there is no way I've worn out a spec stage 3+ in 2,000 miles, so what would keep the clutch from fully engaging? Is it possible for the pedal to come back up, but the fluid not make its way back to the master cylinder? Seems like the pedal would stay down in a case where the hydraulic slave wasn't compressing. My clutch pedal did have a not so smooth feeling a few weeks ago. When letting it out it was not a smooth transition, felt almost gritty, very strange feeling.
I know the pressure plate bolts backing out is one possibility.
This happened right before I got home, so i'll take it out tomorrow and datalog it. If I have to pull this freaking transmission again I'm going to scream!
It's possible I was smelling burnt rubber and not clutch, it didn't quite have that obnoxious clutch smell, but I don't normally smell anything when my tires spin. I will put my drag radials on tomorrow and there will be no doubt.
Well I think it was a false alarm, must have just spun'em up really fast. I couldn't really test it yesterday like I wanted, but I did do a 3rd gear WOT pull up hill and it did not slip.
I think the smell was just exhaust fumes, rubber and possibly belt slipping. I always seem to have a burning smell after a full throttle episode.
I was planning to order the steeda kit once my snout started leaking. Doesn't look like that's ever going to happen though. So how much boost are you making with that belt drive?
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
