surpentine belt jumping
When it jumps the crank pulley the belt will get damaged by the flange on the crank & it will jump again. Change the belt again.
Make sure you have the correct belt. The parts store almost gave me a 5 rib instead of 6 rib replacement.
Mine jumped from oil getting on belt from leaking SC seal.
Problem solved, had purchased a belt from auto zone and their belts do not have a deep enough groove and the ribs look too wide. Purchased a Gates belt, and it solved the problem. Thanks to everyone for the help. I'm ready to BURN rubber!!!
jwog666
12-27-2021 08:09 PM
autoedit
09-27-2015 06:37 PM
