Coolant flush and now.....
2009 gt 42000 miles..
i just did a radiator flush (drain the old fluid and put new ) last week, and now when i use the heat i smell antifreeze. i never had this problem before. I did everything right with the flush. Any opinions?
Can i take out the radio or glove box to see the actual heater core to see if its leaking?
i am NOT loosing any antifreeze
any help is appreciated guys!!
You could remove the radio and/or glove box or just grab a flash light and poke your head under the dash in the passenger side footwell. I did a flush this summer (actually did it twice) and have noticed a few funky smells this winter when using the heat. Check all of your connections to ensure they're tight and that it's not leaking in the engine compartment.
Repeated the process again the following day for good measure.
