has anyone blown their motor N/A - Page 2 - MustangForums.com
Old 02-24-2013, 06:40 PM
DTMR
DTMR's Avatar
Originally Posted by jpplaw View Post
Yep, just upgrading to have a forged bottom end so I can turn up the boost a bit. There is about 80k miles on the stock bottom now, so I figure its better to be safe than sorry.
Brent is going to dynotune the new motor, so it will be a safe reliable beast!!
Yeah I plan on doing a 301 stroker from eagle eventually with high compression pistons but for now I just wanted to upgrade the heads and I wanted to know that it won't blow and have a piston kiss a valve on my new heads. Yeah I was planning on getting A set of frpp heads but I didn't know if I should go with stage 1 or stage 3. I see ford offers 3 different heads for it? I saw A stage 1, stage 3, and a big valve head. So you think with my frpp cams im better off getting a stage 1 head?
DTMR is offline
Old 02-24-2013, 07:39 PM
jpplaw
jpplaw's Avatar
FRPP has stock heads, mild CNC ported heads (vpA - Stage 1) and the big CNC ported, big valve heads (vp3 - Stage 3). I am getting the mild ported versions. With the hot rod cams I would stick with Stage 1's, considering the 3's are like $1400 more than the 1's for not much more, if any, gain.
On the other hand, a set of Stage 3's with some Comp Cams 127400's or 127500's would be pretty wild (but probably not that streetable)
jpplaw is offline
Old 02-25-2013, 06:58 PM
breathegood
I would strongly recommend waiting on the heads until you are ready to pull the trigger on the stroker unless you frequent the track or don't daily drive your car. The combination you have now breathes about as good as it's going to. Bigger heads may open up your top end a little bit, but your low end torque will suffer for it. The $/HP is pretty high for what you get with big heads on an otherwise bolt-on, N/A motor. Granted, my experience may be biassed because I live at 6000' and the ambient barometric pressure isn't enough to generate decent intake velocity with the p&p'd heads, but the principle is the same.
breathegood is offline
firehorse02
11-16-2015 12:28 PM
Dathan
10-05-2015 06:52 AM
UrS4
10-03-2015 07:23 AM
Explosive
10-02-2015 08:45 AM
logan409
09-26-2015 08:43 PM
Quick Reply: has anyone blown their motor N/A
Featured Sponsors
