Help with starting issue...
Last week on the way to work, I pulled over for gas. When I restarted my car, my radio and clock reset. When I got to work, I turned off my car, then tried to start it up again to see what happened. It wouldn't start, seemed like a bad battery.
When I left work, it started fine, and I made it home. But y'all know how when you open and close your door the window pops down and up a bit. It came down, but didn't go back up.
This happened to me last year, and I changed out the alternator and battery. I took both to be tested today, and both were fine. I have no aftermarket electronics and only added a K&N intake. Any suggestions of what the issue could be?
That happened to my wifes truck, but it wasn't loose, there was an actual break in the battery termal caused by acid corrosion. I was pulling my hair out trying to find the problem.
dalefrancis88
09-11-2015 07:15 AM
