Give me some suggestions..
Okay so I have a 2006 GT with headers, o/r x pipe and slp loudmouths with 3.73 gears. Time to upgrade some lol, I need some suggestions for a cam. I was looking at frpp hotrod cams but I heard they don't make as much power as other cams, I want sound and power. Mostly power, but I want that aggressive idle also.
Also planning on changing gears, should I run 4.10s with the cams? Or could I do something more steeper? I'm not going f/i atm, that'll be awhile. Also planning on getting a 3k, or 3500 stall torque converter.
Stay at 3.73, the difference between those and 4.10s isn't worth another $500+. I would spend that money on traction. Like lower and upper rear control arms.
Can't answer about cams, but from what do I understand you might want to look into cams that are springs required with a phase limiter to start making real power. That would sound so awesome too. Most people around here make a little over 300 RWHP with Hotrods and the same mods you have.
I can get gears installed for $175 here from a trusted shop. How about 4.56 instead, until I go with a supercharger? & I might also go ahead and get a ford racing intake manifold, with a cold air intake. Possibly a new throttle body with it, then eventually get ported cylinder heads.
Matt's 95 Stang
10-05-2015 07:16 AM
