system running too lean bank 2
so i just finished installing my hot rod cams. after couple of hundreds of miles driving around i get a system running too lean. told bama about it and their saying its a mechanical problem. wat do u guys think??
i just got a bbk throttle body too and i noticed that thing hisses a lot idk if its normal or not.
Either way, I'm glad to hear you got it figured out and it wasn't related to the tune. Let me know if you ever have any further questions!
-Dan
While reading this I was going to say did you check the Cam Sensor. This is very common when installing cams. You get so excited to start the car up and drive around that it can sometimes slip your mind to tighten everything up! I've done it before myself.
-Dan
-Dan
I look forward to speaking with you.
-Dan
