Which Heads and Cams? FRPP,Comp?
Old 05-09-2014, 01:38 PM
AMWill
Former Sponsor
AMWill's Avatar
Originally Posted by Mellowdien
Yes, i'm already running 3.73 gears. And have access to VP racing 120 unleaded fuel.
I've been a customer of brenspeed, lethal and americanmuscle. However they seem to be partial to F/I beyond the usual bolt-ons or direct me to the typical solutions (which i dont mind if its the best way) like just getting everything from FRPP or Comp.
I'd just like to get some input from a person on here who has been through this route or atleast that knows of a shop or person that can help me out. (since i will also be needing a remote tuning session)
By the way, do i still need CMDP's when i get an Intake manifold???
If you want to go the naturally aspired route, either of the cams you listed work well. To add more onto the cylinder head options. You'll hear a few guys mention they lost low end torque when porting the cylinder heads. This is true if that's all you modify to the heads. However, the only way I would send the heads out to be worked on (if N/A), is to have them ported AND milled. Milling of the heads can bump your compression up considerably. More compression = more power and torque if you're N/A. Unless you're going to raise the compression too, porting is not worth it.
Also, the Ford Racing intake manifold will delete the charge motion plates. No need to purchase CMDP's if you're using that intake manifold.
Hope this helps guide you a little bit! Hit me up if I can be of any other assistance.
Shane
AMWill is offline
Old 05-09-2014, 02:59 PM
jpplaw
jpplaw's Avatar
Remember, there are two different versions of ported heads from FRPP. Nothing wrong with running FRPP stage 1 CNC'ed heads on an N/A car. Yes, I am F/I, but most of the time I am not in boost and the car still pulls like a freight train with stage 1's, 127450's and 3.73 gears. I wouldn't be afraid to put stage 1 heads and at least Comp 127300's on an N/A car.
jpplaw is offline
Old 05-09-2014, 08:12 PM
SpartaPerformance
SpartaPerformance's Avatar
Where are you? 12.85 on slicks and skinnies?? I ran 13.0@107 with a horrible 2.01 60ft on the stock BFG's and that was before the ARH headers. Soemthing aint right, fix that first before you waste anymore money on mods.
SpartaPerformance is offline
Old 05-12-2014, 11:20 AM
Mellowdien
Mellowdien's Avatar
Thanks for the info guys. This helps alot.
@SpartaPerformance, We just have a horrible track. The fastest car here, an '13 Cobra jet average's around a 1.6 60ft time. I've tried numerous techniques to drop my 60", flash stalling, foot braking at different rpm's, dropping tire pressure. Non of it seems to get me under 1.9 seconds. I ran different tires last time, 26 x 10.5, this just resulted in more tire spin. I did get a slightly higher trap speed.
Dragracing in the middle of the amazon rainforest
Mellowdien is offline
Old 05-23-2014, 12:15 PM
BigBlueBomb
BigBlueBomb's Avatar
Default Engine Rebuilt - now having performance issues
Sorry for coming to this discussion late.
06 Roush Stage 3 - rebuilt engine with forged pistons & rods, 9.5:1 compression, FRPP CNC ported heads, Comp Cams XFI-NSR Phase I, 47lbs. injectors, GT 500 TB, Cold Air Intake, Cobra Dual Fuel Pump, and 8lbs. of boost. First dyno pull revealed pegged MAF so changed to SCT 5000. Getting 436hp at the rear wheels. Problem is .... no guts between 2000 - 3000RPM and worse than that is when I punch it I get alot of chocking and studdering before it starts to take off. What have I done wrong????????
BigBlueBomb is offline
GimpyHSHS
19
12-19-2023 01:12 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
Florida Regional Chapter
09-30-2015 08:04 PM
junior04
09-28-2015 10:53 AM
Quick Reply: Which Heads and Cams? FRPP,Comp?
