Will it happen? Throttle body recall.
The chances of a recall at this point are pretty slim, it's almost a 10 year old car. There have been some reports of TPS-related issues on the early build cars. There is a "round end" and a "square end" version of the TPS best I remember. One is good, the other is not, but I don't remember which is which.
7+ years on the forum and the # of OE TB problems has been incredibly small, especially compared to the alternator problems and there was no recall there or even a TSB. Nor for the 05 thru early 06 gauge issues... nor for the 05 and 06 Slacker 500 battery drain issue...
When I clean my TB, I just open the plates as far as they'll open under light pressure. I found on mine there's just enough clearance to get a small brush into opening to clean with TB cleaner. I've got 55k on mine with no problems yet and 2 TB cleanings at least.
Considering the dozen + TSB's on the S197 since inception from '05 AND the fact that most of those TSB's are related to more/other serious issues (take the TSB for the chronic water leak which eventually destroys the SJB for instance) AND the fact that Ford didn't do any recalls for those, there's no way Ford would do a recall for a not-very-frequent TB problem. Even the OE alternators and/or batteries which probably 30% of the forum has had high mortality rates with never even made Ford blink.
JDWalton
09-24-2015 08:47 PM
