Mushroomed a flywheel dowel pin
Old 02-16-2016, 02:03 PM
6bangr
6bangr's Avatar
Default Mushroomed a flywheel dowel pin
I am installing a new exedy flywheel and clutch. I hammered in the first couple dowel pin into the flywheel and somehow ended up mushrooming the third one. I then noticed that one of the other pins had been slightly mushroomed as well. I used a dremel to grind down the two dowels enough so that they fit in the pressure plate.
Will this cause any issues?
If so, should I be looking to install new dowels or just remove them and install the flywheel with no dowel?
6bangr is offline
Clean 14
02-22-2016 04:23 PM
UltraBlue91'
02-18-2016 09:33 AM
02-16-2016 06:54 AM
Clean 14
02-15-2016 05:17 PM
guitarman376
02-11-2016 09:08 AM
Quick Reply: Mushroomed a flywheel dowel pin
