Whats your 4.6L V8 Engine mileage ?
Old 09-18-2018, 06:03 AM
  #31
GT Nate
GT Nate's Avatar
2010 GT 64K
GT Nate is offline
Old 09-18-2018, 08:34 AM
  #32
Stringfellow
Stringfellow's Avatar
Default 84897.2 is my mileage.
Stringfellow is offline
Old 09-20-2018, 12:38 AM
  #33
Vidgomd
Vidgomd's Avatar
37k only needed alternator and 1 battery 2005 GT oh and a throttle position sensor almost forgot because it was years ago
Vidgomd is offline
Old 09-30-2018, 10:25 AM
  #34
bl817
bl817's Avatar
2005 GT 68k
bl817 is offline
Old 09-30-2018, 08:36 PM
  #35
Rocket Ray
Rocket Ray's Avatar
Coming up on 30K. No problems so far, but I did change the plugs to the Champion one piece one a long time ago.
Rocket Ray is offline
Old 12-26-2018, 08:24 PM
  #36
cooperriver
cooperriver's Avatar
I'm the only owner it has 107,000 miles(born September 2004) The alternator was replaced under warranty. The Shaker CD player has been replaced and now the present one doesn't work. The battery has been changed three times. Air Conditioner runs hot sometimes. The transmission(5-Speed) was redone and clutch replaced. The rear Main seal was replaced under warranty. Ball joints replaced under warranty. The car has been driven hard for years. Doesn't smoke or burn oil.
cooperriver is offline
Old 02-13-2019, 12:51 PM
  #37
G&T's GT
G&T's GT's Avatar
'05 GT with 184000, Still running strong.. Not burning oil or using fluids.. Just have to love them..
G&T's GT is offline
Old 02-14-2019, 11:21 AM
  #38
Ford_Dude
Ford_Dude's Avatar
2006 GT almost 200,000 miles.
Ford_Dude is offline
Old 02-17-2019, 07:00 PM
  #39
DoniZ
DoniZ's Avatar
2006 GT, 144k. Just changed Sparkplugs around 1000 miles ago without breaking any, but stay away from champion plugs im going to change them again back to oem cause they suck
DoniZ is offline
Old 02-18-2019, 05:54 PM
  #40
bl817
bl817's Avatar
did you gap them properly? .0054 is what it should be. the champions are the only ones you can easily gap as they aren't the stirrup design. those need a special tool. IMHO id stick with the OEM 2 piece plugs with the recommended nickel anti-seize on the snouts. good luck
bl817 is offline
Quick Reply: Whats your 4.6L V8 Engine mileage ?
