P0012 05 4.6 3v
Ok,
I finally had time to work on the car again. I took the chain off count links paint the links on the end. I put it together and all seems well. When I put it together however I am behide my painted mark on the cam but spot on on crank. I fired it up and she sounds strong and idle for awhile with no timing or misfire related codes. I do have a slight popping at idle but sounds allot like a exhuast leak more then anything.
So should I redo it or is it fine?
P0012 code phase 2
Ok he's an update. I tossed the car back together and God is it a beast. Funny thing I I never had a reason to run over 3500 rpm till today. I went to work did my 10hours go and leave and decide to check my codes. Lone be hold po0012 code if up. I knew I was one cam tooth gear off I was behide my paint mark on tooth.
IS this enough to make the code pop.
Someone please answer this is starting to drive e me nuts let alone the time and work in this.
Mstang1
08-08-2009 12:44 AM
