Caliper bolt won’t tighten
Old 05-26-2018, 09:06 PM
artsvettes73
artsvettes73's Avatar
Never had to hold the slide pin, It is square and if it is seated right it won't spin.
artsvettes73 is offline
Old 05-27-2018, 01:38 PM
08'MustangDude
Banned
08'MustangDude's Avatar
I have had them spin on me plenty of times, so I just pointed it out.
08'MustangDude is offline
Old 05-29-2018, 07:40 AM
ohskigod
ohskigod's Avatar
Just an update, slide bolt has been changed. It was remarkably simple, old bolt slid right out (I only have 16000 miles....the car is like brand new), new one went right in....i used brake grease on it according to procedure, mounted the rubber boot...tightened to about 30 lb feet.....easy peasy.
Also did the lower control arms to boot as while I did many suspension mods, I never did them. Apparently you are only as strong as your weakest link, and apparently I had no idea how weak the brakes and LCA's were. A mild but very significant difference in the car overall and of course the confidence in braking is lightyears improved.
ohskigod is offline
Old 05-29-2018, 07:41 AM
ohskigod
ohskigod's Avatar
oh, I learned the flat part on slide bold lesson the week before when I initially installed the brakes....... :-)
ohskigod is offline
Old 05-29-2018, 07:51 AM
ZEN357
ZEN357's Avatar
Sounds like you stripped the threads.
ZEN357 is offline
RDT
12-06-2014 11:13 AM
89anthonygt50
05-05-2014 09:42 AM
school boy
16
05-01-2010 07:07 PM
stevenn1
11-17-2008 02:16 PM
josh662234
03-20-2007 12:06 AM
Quick Reply: Caliper bolt won’t tighten
