2007 GT Convertible HEATED SEATS issue
Old 12-18-2018, 04:16 PM
emsguy4you2
emsguy4you2's Avatar
Default 2007 GT Convertible HEATED SEATS issue
Bought car recently, 145K miles, great shape, BUT the heated seats don’t work, on EITHER side.
Fuse...25amp mini is intact. Both mini relays behind the headlamp on/off switch were replaced, just in case they were faulty.
Both push buttons activate (the red dot light comes on) and I hear a faint click at the relays when the on/off buttons are pushed to turn the heaters on.
Can BOTH seats’ heating elements be bad? Both elements (upper and lower) on BOTH seats? Ideas/suggestions?
emsguy4you2 is offline
Old 12-18-2018, 05:28 PM
08'MustangDude
Banned
08'MustangDude's Avatar
With 145K miles, yeah, the heating elements could be bad.
08'MustangDude is offline
Old 12-18-2018, 06:59 PM
Moderator
JimC's Avatar
I can tell you that on a 2017 it is a control module that causes everything you said. Mine is at the dealer right now to get it replaced. Supposedly an easy part swap and the HVAC will work properly.
Maybe the 2007 has a control module as well that is causing your issues. Mine wasn't any relay or fuse - I checked those before taking it in.
JimC is offline
Thundersteel
02-13-2015 09:49 AM
XID_AZ
02-06-2012 01:11 PM
devildog1679
01-24-2012 11:49 PM
prinja
12-23-2008 06:54 AM
Andrew54
11-02-2005 02:56 PM
Quick Reply: 2007 GT Convertible HEATED SEATS issue
