05 Mustang Wonít Start; PATS locked??
Old 04-14-2019, 03:36 PM
Mach1BBFun
Mach1BBFun's Avatar
Default 05 Mustang Wonít Start; PATS locked??
When turning key, nothing happens, no radio, no dash lights, nothing.
The anti theft light still flashes red.
Hereís what happened: I was backing the car in with the trunk open, I turned the car off to check how I was aligned, doing so I locked the steering wheel and pulled the key out. Got back in, unlocked the wheel and now get nothing when I turn the key. I can get the car to lock, headlights on, even the alarm to go off, but nothing when I turn the key. Oh and no roll up windows...
Battery is good, starter and main relay good (swapped from other working 05 mustang).
Before I tow to the dealership, anybody have any tricks?
Sounds like the pats system is locked based on research.
No I donít have another key.
Mach1BBFun is offline
Old 04-15-2019, 02:35 AM
Dino Dino Bambino
Dino Dino Bambino's Avatar
Disconnect the battery for 10 minutes to reset the PCM and try again.
Dino Dino Bambino is offline
Old 04-15-2019, 06:16 AM
Mach1BBFun
Mach1BBFun's Avatar
Already attempted battery reset.
Old 04-15-2019, 12:27 PM
Dino Dino Bambino
Try leaving the key with the ignition in the RUN position for at least 30 seconds.
Old 04-15-2019, 01:08 PM
08'MustangDude
Nothing you did would have caused the failure, so it was a coincidence.
Could be the ring at the lock cylinder is bad, and not powering up the
transponder in the key.
The security light will blink a repetitive pattern if it's an error, you can look that up.
If it is not blinking a pattern, then it's not a communications or module failure.
If it's simply not detecting the key, and the PATS system is functioning, then
the key is not getting power from the ignition cylinder.
08'MustangDude is offline
Old 04-17-2019, 07:03 AM
Mach1BBFun
Mach1BBFun's Avatar
Thank you all for the replies.
It was the #68 fuse under the hood: 20 amp, Ignition.
Iíll be sure to check everything next time and not just the relays.
Old 04-17-2019, 08:33 AM
Dino Dino Bambino
Glad it was an easy fix.
norville
08-03-2016 10:05 PM
downtowncanada
02-29-2012 07:03 PM
Tylus
01-16-2010 05:08 PM
redass02gt
Off Topic
16
05-31-2007 05:39 PM
02DKBLUE
03-15-2007 02:16 AM
Quick Reply: 05 Mustang Wonít Start; PATS locked??
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
