05/06 Mustang Supercharger Tech
Old 12-27-2012, 06:19 AM
  #181
CVA
CVA's Avatar
I would agree with Mike, if you want max hp on the stock engine, skip the long tubes and get KB. As he said only use their tune. With tuners, like everything else, there is a variety of skills and honesty. All that said, almost any supercharger with the factory tune designed for the stock engine will make you smile and do the trick. My Rotrex was awesome but even with extensive chassis, brake and wheel/tire changes it confused the traction control so I had to turn it off. Thus, I was afraid to have anyone else drive the car for fear they would put it in a ditch or do a quick 180/360 coming out of wallmart. Bottom line, I took it off and put it in a box in my garage. Now I have a quick, stock looking Bullitt and I'm over the HP urge. (Can put it back in a weekend though!)
CVA is offline
Old 02-26-2013, 01:18 PM
  #182
barspeedhollywood
barspeedhollywood's Avatar
Saving for M90 VMP 500HP kit here. Live in California so...
I think m90 VMP500 kit, all bolt ons, complete suspension set up, alum drive shaft, detroit rocker supercharger grind cams, high flow heads, JBA 50 state shorty headers and high flow cats will make for a very powerful, fun and California friendly set up from ALL my research...
If you don't wanna drop $3,000-$8,000 (Depending on you installing or paying someone to install) on beefing up internals go with M90
Your State might be less strict
barspeedhollywood is offline
Old 08-29-2013, 06:16 PM
  #183
mfrentress
mfrentress's Avatar
I'm doing that now, using Kellog stroker crank, Manly H-rods and Diamond pistons.
Should be bullet proof and lay down about 550rwh.
mfrentress is offline
Old 09-10-2013, 06:04 PM
  #184
gunghojoe01
gunghojoe01's Avatar
Default Saleen S281
Do the supercharger itself use an oil?
gunghojoe01 is offline
Old 09-11-2013, 09:32 AM
  #185
mfrentress
mfrentress's Avatar
Yes, it comes serviced with oil and requires changing every 50,000 miles.
Old 05-10-2015, 02:38 AM
  #186
loots06
loots06's Avatar
Originally Posted by hollywood7721
does anyone have some good advice on what i should get to build up my low end in my 2005 GT with 4.6L (pistons, rods and crank) to handle 12psi of boost?
You do the Boss connecting rods, forged pistons, stock crank, better oil pump and call it a day. There are plenty of options out there for the 3v. I'm going 10:1 with some boost.
loots06 is offline
Old 01-20-2016, 09:38 PM
  #187
Invective
Invective's Avatar
Lightbulb
Enjoyed the read. Been wanting to s/c my '05 GT/auto since I bought it with 6k miles back in 2011 - has 21k miles at the moment. I want to stay safe and look and be as reliable as OEM. Gaining a bit of knowledge here.
Invective is offline
Old 01-21-2016, 07:43 AM
  #188
Simon1
Simon1's Avatar
You thinking of a particular blower?
Simon1 is offline
Old 01-23-2016, 06:28 PM
  #189
Invective
Invective's Avatar
Lightbulb
Roush, as there is a Ford/Roush dealer not far away. Bought my current pickup truck from them in 2006. Will most likely go there for the airbag recall on both vehicles.
Old 01-31-2016, 05:43 PM
  #190
808muscle
808muscle's Avatar
Roush blower kits are awesome on your year. I have installed several of them. On some websites like AM it will say the roush 2300 kit is for manuals only. That is NOT true. Its the same kit for auto or manual..you just need to get tune somewhere else as Roush does not offer a tune for the auto for that kit.
808muscle is offline
Quick Reply: 05/06 Mustang Supercharger Tech
