'91 Ford Mustang
Hi,
If its a 91, the relay is in the CCRM (Constant Control Relay Module) located where Sleeper said, on the passenger side strut tower. Unfortuantley, you will have to replace the whole unit. It also houses the Fan and A/C relay as well. I had to do the same. Make sure the part number matches the one for your vehcile as theres several of them. I went to a Mustang junkyard for mine. I paid i think $90 for it.
You could try jumpering the wires too to make sure it is the pump is working as well.
I might have a wiring diagram around here somewhere if you need it.
Good Luck
Heres the link to the wiring diagram for it - http://www.allfordmustangs.com/forum...rm-pin-out.jpg
Good Luck
Diode Dynamics
28
05-26-2022 12:02 PM
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
10-01-2015 09:11 PM
08-10-2015 01:44 PM
