Swaping 2.3 manual for 5.0 automatic
I have a 1992 mustang with a 2.3 manual in it. I want to swap it with a 1992 5.0 automatic. The 5.0 comes with the computer and wiring harness and the steering column. My question is, what else do I need to be aware of that will need to be replaced for this to be a working swap?
a double hump trans crossmember and an exhaust. You will also need a pilot bearing from a 80's diesel ranger as well if you keep the 4 cyl T5 along with the new bell housing. A new fan will also be needed. If you keep the AOD you will also need a trans cooler and lines.
mungodrums
Suspension
02-09-2016 09:05 AM
mungodrums
10-07-2015 04:01 AM
mungodrums
09-29-2015 09:18 PM
mungodrums
09-22-2015 08:36 PM
