transmission question
Go to this page: http://tjstransmissionparts.com/
In the upper left corner, you can enter the make , model and engine. It will then tell you what transmission you’ve got.
c-3 and a4ld not the same. True the a4ld is later version of c-3 unsure what parts will interchange. Maurice
Edit if decide to do this be aware the a4ld is not the strongest trans and have history of failing and being expensive to fix. I highly recommend a larger trans cooler if thinking of abusing it. Also change its fluid often.
a4ld picture.
http://www.gottransmissions.com/blog...RD-A4LDtop.JPG
c-3
http://www.crankshaftcoalition.com/w...identification
a4ld picture.
c-3
AmericanMuscle4.6GT
11-10-2015 02:06 PM
LivingInThePast
09-16-2015 12:20 PM
