4 Cylinder General Discussion For non tech 4 Cylinder owner chit chat
Turn signal trouble 2.3l LX Convertible
Old 04-28-2013, 01:52 PM
RickG
RickG's Avatar
Default Turn signal trouble 2.3l LX Convertible
My turn signals just quit working. I have checked the fuses, the relay, and have replaced the switch on the column. Neither the indicators in the cab nor blinker sounds are working. When I turn on the hazards only the right indicator light blinks.
What else could it be? Help is greatly appreciated.
RickG is offline
Old 05-01-2013, 09:28 AM
PNYXPRESS
PNYXPRESS's Avatar
Blown bulb?
PNYXPRESS is offline
Old 06-23-2013, 07:41 PM
Daniel Bente
Daniel Bente's Avatar
I have the exact same issue and all bulbs are good. Relay is fine, column switch replaced, fuses okay... Hazards work fine and only the right indicator works when they are on... ANY help is appreciated.
Daniel Bente is offline
Old 06-23-2013, 08:52 PM
Daniel Bente
Rick, I may have found our problem. Under the dash and behind the stereo is a small relay for the blinkers. It is a Wagner blinker relay (part number 224 12V). It is what you actually hear switching the blinkers on and off as it actuates. It is about 1 1/4 inches around and has two males plug in spades coming out of it. It looks just like the relay in the fuze box but a little smaller. I will try and change mine out tomorrow sometime and see if it is working. I will reply back asap to let you know.
Pyrate Dave
09-10-2015 07:30 PM
spamedic
09-09-2015 12:15 AM
Jose Corretjer
09-08-2015 06:32 AM
Quick Reply: Turn signal trouble 2.3l LX Convertible
