Found a part rolling around. What is it?
Tonight on the way home from work, I found a part that rolled out from under my driver's seat.
It's a small aluminum cylinnder, maybe an inch high, and an inch in diameter. It's definately hollow.
The bottom has 2 plug prongs coming out of it, at 90 degrees to eachother, that form a bit of a "corner"
On the top is written:
"552 12V
Wagner
DOT"
On the side is written:
"Motorcraft
D2AB-1330-AA"
What is it?
"552 12V
Wagner
DOT"
"Motorcraft
D2AB-1330-AA"
What is it?
RE: Found a part rolling around. What is it?
It's definately not the top part of an IAC. It feels like it's made of very thin sheet aluminum, and is hollow. The top of the cylinder just smoothly flows into the sides with no sensor plugs. There's just a lip on the bottom, with 2 prongs that look just like your standard socket plugs, but not parallel, angled out. No grime so it's likely not an engine compartment piece...
I have no camera, so no luck there.
hey, im not exactly sure either, but couldnt that be part of the power seat assembly? i think i remember my car having somethig like that attached to my seat brackets. i dont know, but i might would check that.
Found out what it is. It's a flasher.
Identicle to that:
http://i10.ebayimg.com/04/i/000/d4/c8/bdcb_1.JPG
If my turn signals work, I assume then that it's not needed anywhere?
Identicle to that:
