tranny probs..
tranny probs..
i am having problems with my tranny slipping, so i have a couple of options... rebuild this one, find another, or a T-5 swap...... trying to find the cheapest and easiest one to do, any suggestions?
its gonna be a while before i do anything because i broke my collar bone in our football game on friday night.. so no hurry, but i would like to hear what you guys have to say about this
Are you keeping the 4 cylinder motor, or are you going to swap in a turbo or v8? If you are going to do a swap eventually, might want to rough it out and save the money for a proper trans.
I don't know anything about the V8 or auto transmission, but around here one can find 4 banger T5's for dirt cheap. 100 bucks for a good working one, 90 bucks for a stock clutch kit. The rest you should be able to get from a junkyard for cheap.
Well, if you're going to keep it a 4 cylinder, I'd swap a 4 banger T5 in. I don't know where you are located, but odds are there are some transmission on craigslist. Or you can go to a junkyard and get the whole setup for cheap. That way you can run a turbo motor eventually.
If you can find a T5 car from the junkyard you can get all of it at once.
It can be very cheap. My 5.0 v8 swap using a 4 cylinder trans cost me about $130 with all parts. I swapped to a c4 I had built & sold the t5 & all parts but the clutch cage. Cost me $150 to do the swap again with a v8 trans.
On my notch it cost me about $160 because I bought a brand new clutch.
As for a4ld, cost depends on if you rebuild it yourself. Auto's usually take me a while to rebuild (with the exception of the c4), & generally the rebuild kits are $70 - $200 for most older ford autos. I would say base it on what you want, auto or 5 spd. Just to warn you though the a4ld will probably take a while to rebuild since it's your first time & due to the amount of parts inside & I would recommend getting a book if you do. I personally hate stock autos, so i would do the t5 swap. But all the same, I prefer built autos by a long shot over 5 speeds.
treesloth
09-28-2015 07:03 AM
jaiidutch
09-14-2015 10:29 AM
