how do you set the timing on my 88 2.3L. i kno on my 86 i loosen the distributor and turn is it the same on these? the timings way off, its around 19 20
Yes, you turn the distributor. You need to check the timing with the Spout pulled out. Set the timing with the Spout out and then re-install it when you have your timing where you want it.
so i had sometime this morning to look at it, and i see no bolt thats around 17 19 the only bolt i see is a 6mm....am i looking at the wrong place i unpluged the wires and checked around it and cant find it.
