93 2.3 liter swap into a 1988 body
I have a 1993 2.3L running gear that I want to swap into a 1988 convertible body. What do I have to do to conver the 88 to accept the eletronics of the 1993 engine? Or can I just swap a distributor into the 1993 block? Im looking for any suggestions before swapping.
Thank you
Thank you
i'm not sure about the distributor into the '93 block. I don't why you would wanna go from the 8 plug set up to the distributor set-up. But I got a buddy who put a '92 2.3 into his '87. He said it requires the the '92 ecu('93 in ur case) and He had to play with the wiring too. I'm not too sure whats involved. Why do you want the '93 2.3 in the '88? Does the '88 still have its original motor?
oops I forgot about the 8 spark plugs. I have a 93 vert that I bought from a guy that moved from Minnesota and the back frame is starting to rust among other things, so I have an 88 vert that is a Florida car with no rust that I bought with the motor in pieces so I was trying to swap drivetrains.
jaiidutch
09-14-2015 10:29 AM
